Last year I bought my dog and rode it 1 day before it wouldn’t start due to what I hope was just failed carrier bearings that had my starter gear binding up bc the clutch was a bit cockeyed. I took my primary apart and the bearings were def shot, but the main shaft nut was tight and there was no play at all. I didn’t realize it was reverse thread and during disassembly I broke off one of the (4) ears on the cast inner clutch hub that the pressure plate bolts thread into. I am already well into 2k just in parts alone, and 10k I paid for the bike which I only got to ride for a day. Someone please help a guy out with a cheap used hub or any compatible upgrade for a complete clutch assembly. Bandit is charging 1100 for a complete assembly that I can’t afford atm, and they wouldn’t be in stock for at least another 8 weeks even if I could. Any help is greatly appreciated. Thank you in advance. Also I’m new to bdm so I’m ignorant to a lot of things, I have no idea if it’s a 9 or 12 clutch pack and what is or isn’t compatible. All I know is it says 3053b dssc on the clutch carrier. 2005 Bulldog-117 w 6spd baker
