Just as an alternative I stopped using heli-coils a long long time ago. I use solid inserts. They can't unravel like heli-coils. I'll look in my supplies tonight for the brand and take a picture. I've done heads, exhaust bolts, etc. and you are then bolting and unbolting into a threaded steel sleeve essentially instead of into an aluminum piece. Never had one pull out or fail.
Here you go! Finally got out to the shop. They have an epoxy coating on the outside to lock in. I used them in Harley heads, stripped exhaust ports etc.2004BC very interested in the solid inserts. Post some pics if you can.
Please tell me what you were thinking. Maybe it's out there and even better than helicoils and EZ-Locs. Definitely open to better ideas!!!!!! :2thumbs:Thanks 2004BC, not what I was expecting but looks more solid than helicoils.
The problem I've found with stainless steel is that if not properly coated it will promote electrolysis in some aluminum alloys. It all depends. I still use SS in aluminum, I just coat it completely with Never Seize or Loctite. SS looks much better than rusty carbon steel!I've used these things called nutserts. They are stainless steel look like a rivet with threads inside. Have to use a special pneumatic gun, insert into hole pull trigger expands like a rivet really strong. sorry no pics. Haven't used them in years, I'll see if I can dig up more info.
True. You need to have enough meat in the metal to tap the OD thread of the insert.I've used both and like the full insert sleeve style over the spring style for better hold and lock but may have to oversize the old hole to insert the full insert sleeve style.
Oh oh - the man has spoken (its not often that we get to hear from the grand master himselfEnd your problems forever:
Timesert.com
Time Fastener Co.
5301 Unit G Longley Lave
Reno,NV.89511
800-423-4070
Regards
Jim@karata
