headlight
bigbc
does anyone know if I can change my headlight to a day maker and keep my oem headlight bucket. if so where can i find it by the way it is a 2003 chopper
Yes. There is actually several threads on this, if you do a search. You may have to loose the rubber seal in order to get the beauty ring all the way back in
so do I just search gore headlights
Most of us are running the daymaker's. They will fit in the stock housing just fine. When you take your headlight apart, there is a rubber seal in there. Because the lip on the daymaker is thicker, and a sealed unit in itself, the rubber seal isn't needed. If you try to use the rubber seal, your beauty ring won't go in all the way, and might fall off, going down the road.
