Keith S
EHC FREE!!!!
I had a recent issue with my headlight blowing and thought it was fixed. I am still having issues and think I have found the culprit, but don't really understand the how/why. I am hoping someone with more electrical knowledge than I can help.
With my last thread, I had an issue with the bike overcharging the battery. This caused the headlight to blow the low beam within a mile and the high beam within three or four miles. It also overcharged a LiFe battery and blew the Wire-Plus switch harness after about 15 miles.
I replaced the VR and Stator with the 40 amp 3 Phase system. When I hooked everything back up, I left my LED accent lights (which have been on the bike since before I bought it in 08) unhooked. This seemed to fix the problem. I road about 15 miles and checked and was getting about 13 volts running (i.e. charging). I went on a second ride about 20 miles and everything was perfect. The headlight worked well. The charging system worked, etc.
So tonight I was going to a bike night 6 or 7 miles from the house. I rehooked up the LED accent lights and the trickle charger before I left tonight. I turned the LEDs on and the back off just to check them. I did not check the headlight before I left. I noticed it was out about 3 miles from the house. The high beam worked but I left it off.
On the way home, it was dark. I wanted to leave earlier, but got held up. I ran the high beam and it was fine the whole way. Close to home, I decided to try the LED accent lights just to see what happened. As soon as I turned them on, the headlight blew. The LEDs stayed on. I live on a country road and could still see so I road a very short way home. When I got home, I checked the battery with it running. Sure enough, it was over 16 volts. I unhooked the LEDs and the trickle charger and it was back at 13 volts.
I am pretty sure it is a short in the LED accent lights, but why would that cause the system to overcharge? And if it is a short, why do the LEDs still work?
The easy solution is to just leave them unhooked, but I like the look. More important, I want to understand the WHY.
Any help is appreciated.
Thanks.
Thanks.
