Don't understand your explanation that well.
If your headlight bucket assembly is like my 2007 then here's some help.
Are you talking about the outer trim ring and the inner headlight retaining ring. Both are held in with small setscrews on the bottom side of the bucket. The screws need to be removed first then the rings should both unscrew. It's more difficult without the tool. Don't over-tighten the screws at reassembly as there are only 3-4 threads in the bucket. If no lock screws are used you risk the chance of loosing the trim ring while riding.
The inner ring has an o-ring on the back side of it and if it's never been removed before then it could be sticking onto the glass. Try some silicone spray with a nozzle tube behind the retaining ring.
If either of the rings are not evenly unscrewed they can cross-thread and jam, so be patient and work them out slow.
The headlight shoud loosen a fall free when the retaining ring is removed.
Here is a drawing for a retaining ring removal tool:
