Handlebars
Actually on the big dogs there real easy because the holes are large enough to fit the plug and all. You can use a wire or fishtape to pull the wire through or sometimes I use a string and a air compressor and block off all the other holes and shove a peice of string in and blow in with an air compressor and the string will come out the exit hole. Tie the wire to the string and pull through.
