i pulled the starter off to get ready to install my open belt from karata,and wanted to clean the starter so i pulled the 4 bolts out and pulled the starter apart,and noticed oil all in there so i took the gears out and wiped everything down,but i also noticed a heavy like grease,is that suppose to be in there for the gears? should i put a small amount back in there around the gears? also can i get a can of electro spray and spray the shit out of it? then blow it drive with my air compresser? i will then take off the other end and clean the contacts while i have it out,i just dont want any of this grease or oil getting on the clutches in the open belt since its a dry clutch.. thanks guys
