Originally discussed in choppersforlife's thread http://www.bigdogbiker.com/forums/how/2824-brake-calipers.html#post45641
If you want to bleed brakes or change brake fluid... this is a great way to do it without tricky pumps and vacuums and things that require a science degree to use...
Our sizes
front 1/4-28 x .921"
Rear 3/8-24 x 1.19"
Got that website from Goodridge themselves. They sell them by thread size not bike model. The prices are for sets so you can split the cost with a fellow dog owner.
Racer Parts Wholesale - SpeedBleeders
You will order for the front SB1428 & rear SB3824
The speed bleeders are a replacement to your bleeders. It has a check vlv in it. After you replace your bleeders on your caliper with this one... that is it. Simple spin them open a bit... and instead of pump pump hold... you just pump pump pump pump pump pump Everytime you pump it pushes out the air or old fluid but with the check vlv it doesn't allow anything back in.
The products:
Rear:
Front:
The old stock normal bleeder
Out
The speed bleeder in
The inner workings of how they work
I have used these before and they work great!! I don't see how doing them on the dog will be any differently besides I only have 2 instead of 3 that I had on the sportbikes...
Our sizes
Rear 3/8-24 x 1.19"
The products:
Rear:
Front:
Out
