Ginz sissy bar mounts
jarnett
Curious if anyone has tried the ginz choppers sissy bar mounts. Specifically the 2003-2004 chopper.
Looking at the pic it's hard to see how they actually mount.
Orignally down for a smoked rear wheel bearing,, pulled my chopper out of storage and currently going down the rabbit hole of everything I want to fix and upgrade while she's down.
Mastiff Rider64
I had them make plenty of stuff for me. The first thing was the mounts for the 09 Bulldog bagger, along with a sissy bar and pad. It was the first time they had made a mount for it, and being honest, the first set they sent me didn't work but after some pictures and some measurements the second set worked perfectly. Now the only regret i have is that instead of going with the diameter on the sissy bar that Big Dog uses, I went with their Diameter bar. Which means I cant use Big Dog sissy bars in the mounts, and now am limited to what kind of sissy bar styles I can use. Even tho my latest project from them was to make a low boy sissy bar and pad that was almost Identical to Big dog's. the only difference is that I wanted this pad to sit higher on my girlfriends back than the original height of the actual low boy sissy bars, and they nailed it. Now i want to add a luggage rack, but forgot the diameter of the bar is different than Big Dog's so I can either get them to copy Big dog's luggage rack and just have them make it fit their bar's diameter or possibly make the big dog one work that i have by adding some rubber inserts. But either way I'm happy with the work they have done for me, even tho they seem to take their time doing things.
If your interested in the original struts & sissy bar for your bike give me a call. Just need your vin# to figure out if it's RT or DT frame.
620-680-0395
jarnett
Curious what size you went with on the bar 15/16"?
jarnett
620-680-0395
It's an RT frame for sure. Stamped on the frame where the coil cover mounts. But here's the VIN for reference
5J11NBJ123W000706
