Gas cap
Clubba
Has anyone else had issues with the gas cap swelling/ hardening due to the E85? Any solution on upgrades of fixes would be greatly appreciated. I literally had to borrow a set of pump pliers to get mine off the last time I got gas.
Coolbreezin
I dont know of any fix. Once ethanol is introduced, its all downhill from there. However to remedy the same situation, I purchased a gas cap add-on that fixed my problem. It mounts via 3 set screws. Its not a great pic but this is it. I paid $25 about 4 years ago.
SB03chopper
Get with Mr Wright, and get the paint saver set up. It has a ratcheting gas cap, so no over tightening, and does not swell.
mleach72
If the paint is still in good shape, you can just get a new cap, but chances are that it happen again eventually. The only permanent fix is to remove the paint-saver and go with a harley cap, or go to something all metal, like what I have. Mr. Wright's fix is nice too.
Clubba
Thank you! Do you remember the name of the manufacturer?
mleach72
On on my second cap with the same issues. Who makes that cap? That’s great!!
It's a guy in Ukraine that makes them. He has a lot of different styles. He is on ebay. Just do a search for big dog gas cap. They aren't cheap. There is a guy here in the states that imports them. You can get them faster from him for a little more money.
pknowles
RETIRED
I thought I had posted in this thread about having a spare stock gas cap. I have one in good shape from a K9. If you can't find what you need, let me know.
mjsk9
Hey PK.... You actually posted in the thread where someone was looking for a fender..
mleach72
Thank you brother
Welcome! If you do get one, make sure he puts a tank vent in it. I think he usually does. I didn't need one because I have a 2 piece tank and a vent under the dash. Also, take all of the acorn nuts off and put a dab of loctite on the screws. I caught a couple of them starting to back off. If it doesn't line up straight when you put it in the tank, get a thicker or thinner o-ring under the cap. Other than that, they are great and I get a lot of compliments on them.
Clubba
That’s a great idea! Thank you!!!
PAUL NOBBS
My original BD cap looked cheap it let water in and was not level on the tank so cut it out and put a lockable vented aircraft style cap in it and looks the biz filler cap.jpg
