jjarkys
I'm not on this site very often, (too damn busy, but I'm stuck at home with pneumonia), so I'm not exactly sure what issue you're talking about. As far as a random shutoff issue, in my experience, most of the ones we've seen have been EHC related.
cajonesvtwin.com
Lots of posts about bikes just shutting off as if the key was turned off. Usually it just takes a simple cycle of the key off and then back on and bike starts right back up. Possible fix suggestions usually range from ehc to cam sensor to key switch to backbone harness, you name it. And maybe it's different for every person and all these things could be the problem. I was just wondering if you had dealt with this and if there might be a common issue that you find more often than others. If ehc seems to be common, what do you usually do to remedy? Thanks.
