2008 mastiff
hi guys i have a 2008 big dog mastiff 117 sns efi with baker 6 speed. went to start bike everything seemed fine but the fuel pump will not engage any relays or fueses on this bike
I've hat the bike for 3 years I've never changed anything in the bikeDo you have the original ehc?
thank you ill check it and take a couple pics i think someone has changed to stuff on the bike before meThe pump is powered through a relay and breaker under the left side cover controlled through the VFI controller, not EHC.
First make sure the breaker isn’t tripped. (Test continuity, or 12v across it)
Next, under the forward side of the tank there is a connector with 4 wires.
After key on, you should see 12V for ~2 seconds for pump prime between the red and black terminals.
If all this is ok, then the pump is bad.
View attachment 77184View attachment 77184
[/QUOTE
[/QUOT
12 volt at red and black wires under tankthank you ill check it and take a couple pics i think someone has changed to stuff on the bike before me
You may want to open a new post for your problem. Your post is pretty vague as written.the 4 wires from the fuel pump and connector is completly gone any ideas what wires go to what wires
