PA Chopper
Hey guys,
I posted a while ago about my front master cylinder leaking. At the time I took off the cover and gasket, wiped everything dry, sucked out a bit of fluid and reassembled. It was okay for awhile and now it is leaking again. I just removed the cover and gasket again and was about to wipe and dry again but I noticed that there is a tiny pin hole in the bottom of the resevoir. Obviously there is the large hole where the fluid goes thru to the line but I see a smaller hole about the size of pencil lead right by one of the stocks where the screw goes in for the cover. I wanted to grab a picture to post but my camera batteries need charged. Does anyone know if this is normal? I'm guessing there shouldn't be another tiny hole in the bottom of the master cylinder. I know there is a vent hole in the lid but this is at the bottom of the resevoir.
