TCALZ06
I've got a problem that seems to get worse with speed but doesn't do it all on roads.Tire wear is the most common, neck bearing wear is second(bearings get small flat spots undetectable in swing the wheel side to side). Play in front end is third and Swing arm play is also a common cause of front end problems. If you remounted your front tire on the wheel make sure you have it going in the right direction.
Where should I look for play in the front end? I put a new front tire on 3,000 miles ago and had dyna beads put in. My wheel bearings were checked at that time too.
I thought maybe I was making to much of it until I was coming back from Laughlin this weekend and on the same road and switching lanes my friends Iron horse wasn't moving at all while mine looked like a jumping bean
