BIGDOGFREDDY
I had some time the problem is that if I wanted to start my K9 that when pressing the RUN - buttons on the Start is enabled (red LED on EHC) is not concerned. Have on the handlebars Start - RUN - open flasher button. Below is an electrical circuit board. On the board are key in the form of "clicker" installed. The thing works is that in the background is just the board. Directly to the board are easily applied only to the board small / tiny springy metal flakes. (without feathers, without bracket, just simply placed only on the board) So this clicker (springy metal flakes) can not slip, is simply a thin film stuck over the board. Caution watch - when you lift the foil / subtracting the fall clicker click frogs, - which are also only as small as your little finger nail to the floor. With this clicker is dirt, polish and polishing wax accumulates. You have to just wipe clean and give a little grease between the circuit board and battery clicker. The film can be stuck back on the board with silicones.
Times to be honest, - such a crap we have not even installed here in Germany in children's toys. How can a developer be so stupid and installing an electrical circuit board that you usually only actually used in the indoor area unprotected and without poetry in a motorcycle. Or maybe the thought that with a BIGDOG
