forward controls and seats
coachk
Jess....you have 2.5 extensions on both sides. You will need to have a shorter linkage rod if you put the stock forward controls on.
Stock linkage rod......16 3/8
2.5 extension rod......18 1/2
^^^^ measured from center heim to center heim.
pknowles
RETIRED
Looks like you have the streamed line seat and the pad goes with a standard seat(without the ridge in the middle) has a little more cushion.
flcmcya
That has the 2.5" extension on the controls.
But what must be most uncomfortable is having that obnoxious down-tube sticker still on it.
This :rant: Downtube stickers hide nicely under the seat.
I'm looking for a swap for my stock to 2.5 as well.. like to stretch out so my leg clears the intake better. ! :up:
wyopsycho
viking
so are these the piece we are trading? I did black arrows both sides of course. also pegs and shifter linkage or do we keep our own pegs and shifter do we disassemble all that?
Viking
Biker
Yes. And they are right about the linkage, it goes with it. If you check eBay there are pictures of the entire setup on one of Donna's listings. We can simply swap pictures after it is all taken off so that we ensure we get every piece needed sent to each other.
Stocker
I have stock control mounts & linkage on my 08 K9 if you would like to trade? If the deal with Viking does not happen.
