08mastiff
Well I got myself into a bit of a pinch. Disassembeld my front end to rebuild the forks with new seals and noticed immediately that the one bolt that connects the fender mount to the fork tube was broken. Apparently the genius before me decided to use red loctite on the thread. After disassembling the front end, draining the fluid and taking the whole unit apart I decided to try and drill out the old bolt and re-tap the thread. Yup you guessed it I made a pin size hole through the lower tube as I was getting the bolt out. :angry::angry:NOW WHAT ??!!!!
I went to the local Harley dealer inquiring for a solution and they suggested wrapping the new bolt for the bracket in teflon tape or using plumber's dope around the threads and assembling it as is. I wanted to know if they could plug weld it and then have it re-tapped. They didn't want to mess with it at all, especially since it's chrome (and probably cause it's not a Harley product). I go home and change the seals and fluids and put everything back together using the pipe dope on the threads. Did about fifty miles on it one day and everything looked good. Today did another 75 and you guessed it......it's starting to leak behind the fender mount bracket down the lower fork tube. No leaks any where else including the other tube. Everything was definitely installed correctly.
Looking for some suggestions before I take the plunge and buy a new lower fork tube. There has to be a way to plug weld it...NO? If need be does anyone have a lower for sale? Its the right side as you sit on the bike. Opposite the front brake.
