Fork Extensions
RLD
I have a 2002 Bulldog. Are there any fork extension kits out there that fit a Big Dog? Also, is there a trick to getting the lower leg separated from the tube? I've been banging on it for hours.
bigkelk9
And ill say it again. These bikes are built with precision and years of engineering and geometry go in to building these bikes so they can handle as great as they do. Get a chopper or a K9 if u want that look.. h ell even get a fury.. lol
Just buy longer 41mm fork tubes.
You'll have to put in a larger spacer to help pre-load the spring if you use your stock internals.
How long do you want to go?
Jersey James
Jersey James
Forks by Frank, Evanston, IL (847 475 1003). He has been making fork tubes since the 1960s, American made quality. And YES I extended my 03 Pit Bull using Frank's fork tubes, (just 2 1/2 inches, over stock) WITHOUT any adverse handling affects...
