electrical / speedo
teryl
04 BD chopper died the other night engine shut off. all lights still on,( like I hit the kill switch) cycled key and nothing on hand controls work and speedo now sweeps from o to bottom of gauge no turn left or right. headlight only on high. no run, and no crank, no led on thunderheart on small circuit board have 3 green lits have the wire plus module
awg
Says Wire Plus module. Sounds like all the problems are up front. I would start checking what works and what don't. Make a list then you can figure out where the problems start and end.
knothead
Could possibly be a short in the wiring on it or the grounds....wireplus has several ground wires....check them out first and all the connectiins on the wireplus
