REMorris
OK Rider Shakey
I would have to say I was blessed with 10,000 troublefree miles. Now all i can say is I can't take it out of the dealership, it dies or will not start
Here is what happened 1st:
I was beginning to get an intermittent start situation. Took it into Iron Lightning and it did the "i don't want to start thing" on them. 2 weeks later, they found the problem. the rear bolt that holds the rear of the tank in place was way too long and had actually worn a hole in my wiring harness big enough to stick the tip of my small finger in it. Also, when they took the ECU off, one of it's mounting bolts got screwed up. So I got a new ecu and new backbone wire harness (and they cut the tank bolt to the correct length so it will not happen again). I got the bike backand was happy for a week.
Next, my bike acted dead (no lights or speedo, nothing) after it was ridden a while. (This was after I shut it off and went to restart it). I ended up disconnecting the terminals attached to the neg post and when hooked back up, it would start and everything seemingly worked. As before, my bike performed this problem for the dealership.
Get this, dealer put yet another new ecu in it as well as a new battery and claimed it was fixed again.
This Thursday, I went to pick it up and it did the same damn thing again (turn key and basically side lights come on, no switches can turn anything on or off and turning key off it still has lights stuck on and of course, no starter activity), unhooking the negative connections allowed it to reset some error condition and it started.
Needless to say, I did not pick the bike up and have make it clear the bike must be able to ride this coming weekend as well as next weekend.
I told them in all cases it was not acting like a bad ecu, but rather that the ecu is doing it's bootup tests and something is not responding back, so the bike's computer isn't fully getting booted up.
I have designed and built robotics for American Airlines, Hilti Industries, Rockwell Aerospace, etc... my point is that I have a lot of experience in dealing with analog and digital systems.
I explained this to them and them told them the following:
This acts like a bad digital ground. The digital ground usually achieves the ground state by pulling the current down with dropping resistors. It the drooping resistors are connected to a <bad> ground, then the ecu can not turn on or off critical electronic switches. So unless the startup code in the ecu has timeout and contnue code happening, and I suspect it does not, the bike will not start and appear dead.
Un-hooking the battery turns it to a fresh start and so far it will start. Oh yes, forgot to mention that when it goes to lockup mode, even turning off the key doesn help, I think the parking lights stay on.
I really like Iron Lightning and have the bike serviced there since new. I am not putting the dealer down, but I got to have my bike for the next 2 weekends.
So, anyone else have this experience and what was causing it?
Thanks for taking time to read this
Richard Morris 918-258-2855 if you have any ideas.
