electrical issues
just got my bigdog already having electrical issues bike has power to all lights wont turn over and blinkers horn high beams nothing works on hand controls anty advise ??
KnotSo
Admin
Do a load test on the battery.
Lot of topics on this issue, do a SEARCH and you will probably find more than enough info to solve your issues.
Banned
we need more info than that.. but as mentioned a week battery will give you many problems.. you need to check voltage a min. preferred is 12.8 vdc.. & yes load test it.. once running you need to check the complete charging system do a search its on here...
ok thanks for the fast reply ! i just noticed there is only one light lit on the ecm and none of the controls work on the bars headlight works running lights work dash lights up but nothing when i hit start or try the blinkers ect
