BigD07
I am having an issue with the speedo/tach/bike shutting down randomly. When riding the tach runs fine sometimes or it will be all over the place, the same thing with the speedo. When there are issues they both go haywire at the same time. When this occurs sometimes the bike will die and either turn right back on or I hit the start button and it fires back up. I have a wiresplus kit, thunderheart ignition and dakota speedo installed. This issue seems to have started with the tach and seems to have gotten progressively worse. I have looked for loose connections and bare wires but cant seem to find any. The issue seems to give most problems when accelerating. The headlight will flicker also when revving. I just replaced the HID with a new bulb assembly, the last one melted a couple wires but the new one fixed the issues i was having with the headlight. I have also pulled the tach/speedo apart and didn't find any loose connections or corrosion. I didn't know if the crank trigger or voltage regulator would cause any of these issues. The battery is a new fully charged braille. When i hook it up to the computer through the thunder heart it says its putting out 13.7V. Also have nothing on the key ring.
Thx for any help!
Thx for any help!
