Fibersnake
Banjo Playing PsychoBilly
Well I was taking care of the clean-up from last weekend ride and doing maintenance on the connectors and have ran into some demons. I have gone through the Flow Chart for troubleshooting as well as the schematics, till the lines are starting to run together.
The problem is that after I put everything back together (putting di-electric grease one at a time, disconnect grease re-connect, on to next). The Speedmeter does not work.
The neutral light is not coming on (thought it is in neutral), Oil Pressure light is not coming on (when not running), Tach does not work.
Everything else works, it will start and seems to run fine. The light on the EHC seem to be working okay though I do have one yellow light when the key is turned on. Run light on EHC comes on when button is activated.
I have rechecke all my connections and then rechecked again. Can not find a bad one. Battery is good and it appears to be charging right.
Only thing I can find that is common to the three is the power wire, but it appears that others share it too. Maybe miss reading the schematics, not sure. Have not done a MM-condunity test yet,, but will check the pins in the morning.
All lights, horn, high low, turn, emergency, brakes, run, start, off, etc work. JUst not speedometer at all-no sweep, no numbers, nothing. No Neutral light or oil light.
Had clean it up and used low water, started fine with everything working after and pulled in garage to do the electrical maintenance. Did pull the battery connections prior to start. All problems seem to start after I was done adding the di-electric and put everything back together and reconnected battery.
Any suggestion!!!!!!!
Would a bad EHC show symptons like these. Anyone know how much one is in case I have to replace??
This is for a 2005 Mastiff BTW.
Thanks
Thanks
