So here’s the thing. The Bigdog RIP replacement is going to require that you remove your gas tank and the connections to everything will be replaced with the new EHC harness. The WSW/ Axle EHC replacement is considerably easier to install. I think 5 wires and a simple repair to the main existing harness connector that allows it to connect & lock it in place and bam your done. 1 hour job. Fits perfectly right where the existing EHC was positioned also. View attachment 125278
I did the BDM rip replacement and I don't remember removing the tank -- it's only 1 part of the harness that gets replaced and it was not that hard of a job when I did it. Worse part was trying to re-orient things to get all the wore in place so the side covers went on easy! (That's on my EFI K-9 anyway) I could be wrong about the tank -- it's been a few years.So here’s the thing. The Bigdog RIP replacement is going to require that you remove your gas tank and the connections to everything will be replaced with the new EHC harness. The WSW/ Axle EHC replacement is considerably easier to install. I think 5 wires and a simple repair to the main existing harness connector that allows it to connect & lock it in place and bam your done. 1 hour job. Fits perfectly right where the existing EHC was positioned also. View attachment 125278
Thanks for the advice. Mine is a DT frame and the battery sits parallel to the frame bit I don't think that's an issue...So here’s the thing. The Bigdog RIP replacement is going to require that you remove your gas tank and the connections to everything will be replaced with the new EHC harness. The WSW/ Axle EHC replacement is considerably easier to install. I think 5 wires and a simple repair to the main existing harness connector that allows it to connect & lock it in place and bam your done. 1 hour job. Fits perfectly right where the existing EHC was positioned also. View attachment 125278
I was referring to the video instructions from Bigdog when installing the RIP ehc to remove the fuel tank. Maybe it can be done otherwise. I don’t know. I went with the Axle EHC and am quite happy I did.I did the BDM rip replacement and I don't remember removing the tank -- it's only 1 part of the harness that gets replaced and it was not that hard of a job when I did it. Worse part was trying to re-orient things to get all the wore in place so the side covers went on easy! (That's on my EFI K-9 anyway) I could be wrong about the tank -- it's been a few years.
I believe the Axle EHC for your year & model is designed to be installed exactly where your current one is. So yeah I don’t think there should be any issues. My .02….get with Curtis @ WSW. He can hook you up. He’s on eBay. That’s where I purchased mine.Thanks for the advice. Mine is a DT frame and the battery sits parallel to the frame bit I don't think that's an issue...
I don't believe WSW is on ebay, I'd email or phone 619-823-8557 or Curtis Adams <wsworx@gmail.com>I believe the Axle EHC for your year & model is designed to be installed exactly where your current one is. So yeah I don’t think there should be any issues. My .02….get with Curtis @ WSW. He can hook you up. He’s on eBay. That’s where I purchased mine.
Well I could be mistaken.That’s interesting considering I bought one from him through eBay in March. Maybe he has sold out of Axle Joost EHC. Or it’s a different Wildsteedworx….View attachment 125303
Well I certainly don't see a store for Wildsteedworx on ebay at the moment but can find bigdogpartskingpin -- I've emailed Curtis for more info.Well I could be mistaken.
