EHC Needed
leandean99
I have an 06 K9, looking for a EHC, bike went through hurricane Harvey, just getting it back on the road, any other options also, thanks.
Wouldn’t just lean on a new ehc as the problem .
If it’s bad recommend axels ehc or docs esc .
Both are good systems .
Mikeinjersey
If your bike got flooded with salt water it may be best to replace your wiring and the EHC . In that case I would go for the new Bigdogisback kit. If keeping your wiring go for (Axels) Electronik Box which is very good plug and play product sold by wildsteedworx.com
awg
I have the early model EHC from Axle. It doesnt have blue tooth or any of the features the newer one's have. I used it for a couple weeks then got hit from behind. Took it off the bike before they towed the bike. It was on a 06 Mastiff.
leandean99
the bike is running now, just electrical issues, lights, blinkers and horn...…. I had to replace front jug, starter and upper forks. I called big dog but I will call wildsteedworx and see what he has. thanks.
If it's running and it's just lights, blinker & horn. It might just be the connection to the EHC. Take it off and clean up all the contacts and throw some di-electric grease and see if that fixes it.
If water was sitting in those connectors it probably by now has just rusted up a bit a light wire brush and blow it out with compressed air and you might be cooking with gas! Worth a shot for no money!
WU5C
Bad Dog
I went with the DOC (Dead One Customs) EHC Best decision that I've made in a while. Easy install and nothing to fab up and it fits original mounting.
