Ehc gone
firedog19
Only one issue with the plug for the speedo as the harness had 2green wires for that plug. One is the neutral light and the other is the tach signal. Had to do a continuity check to determine which one was which
Had my ehc replaced with a big dog pdm retrofit kit on a 2009 k9 and now been told tachometer needs to be replaced?
Tachometer will not work now that ignition module was removed and was told crank position sensor will no longer be used. I had a Daytona twin tech ignition installed a year ago
Any help would be appreciated
Thanks
bearman
......2009 k9 and now been told tachometer needs to be replaced?....Tachometer will not work now ....... I had a Daytona twin tech ignition installed a year ago
Thanks
Don’t know why you would need to replace the tach. Just hook it up to the new ignition.
In the installation instructions I looked up online, the Datona twin tech ignition should have a brown wire for the connection to a tach, if you are still using the stock type single fire coil configuration.
