Dynatek 2ki problem?
Slider
So went for a long ride today with friends, 90 degree weather in the mountains.
After stopping at a watering hole, get back on bike, fires up, running great. Stop about 25 miles down the road for about 30 minutes, get back on the bike, cranks strong but wont start, no spark to plugs from coil. Pull nose cone cover to check the dynatek 2ki. Led indicator is supposed to flash when you turn on the key, no flash. Can't get led light to flash at all. Btw, got the 2ki when I did the wire plus. Bike cranks like crazy just no spark. :confused: pulled coil cover, everything looks great.
I know just to hit the start button and not the run button first after turning on the key.
All the lights on the wp power module are lit when bike is cranking, just no spark.
Will trailer the bike home tomorrow night after work, locked it up on the street for now. :bang:
Anything else you would do to troubleshoot? Thanks.
Ill assume though that you did you try hitting the Run button first? I need to hit the run button on mine to send power to the ignition module.
Slider
Yea tried it with and without hitting the run button. Gotta run up north 100 miles to get her tonight.
