Dyna S and Dyna coil
Gunnar
Has anyone used those two. My bike has installed 2 wire (blue,white) sensor which should be connected directly to coil (thats how I understand it). Thunderheart module is skipped in wiring. Problem for me is that I have no idea how the wiring should be. Its single coil, no pos or neg markings, only 3 ohms marked on it and Dyna writing.
Ifs its dual fire it doesn't matter. Both cylinders fire on compression and exhaust stroke
Sent from my DROID RAZR using Tapatalk 2
DRBarnhart
Insert title here...
The white wire should be connected to the same terminal on the coil that goes to 12V (from your kill switch) and the blue is connected to the other terminal of the coil.
If in doubt ask for clarification!!! :2thumbs:
D
Ops :)
DRBarnhart
No need for an "Oops" Ray. I pretty sure the Dyna coils aren't marked with + and - so it doesn't make any difference which way you hook the white and blue wires from sensor. The thing that is important is that the power wire get connected with the wihite wire.
Dennis
Dennis
Gunnar
D
Thanks, thats actually what I assumed. Manual from Dynatek is bit confusing in this part, there is clearly written that white goes to + side and blue to -. But that this is for you do decide isnt written :) Then there is no difference also into which connection which sparkplug goes ?
