Dyna 2000i Need Help
maa323
Need to replace my Dyna 2000i. My question is can I mark the old unit carefully so to get the new unit in its exact place, or due I have to take it in and spend the money to Dyno tune it ? Any ideas ?
Little-Boo
I don't any experience in with what you are replacing, however if what you are replace are identical parts just mark and replace and you should be good to go.
Carlos :whoop:
maa323
Its the ignition module, it has the cam sensors built on it. I just want to make sure it mess with timing.
MARV
It has a led light to set static timing at TDC which is usually close enough
Then if you want dynamic timing for a built motor then you'd need a timing light to set it to your compression
maa323
Thanks Marv
I have a 107 that the heads have been ported polished and decked, bigger valves and heavier springs. A more aggressive cam and a psi carb. Not sure where the compressiom ended up, but I know its up there.
Atortella
Have same dyna 2ki took it out many times and replaced never had to worry it. It should be fine but if it's not it is easy to find TDC with the lights.
Moespeeds
I think you could static tune that, and then get the curve right by playing with the dip shit switches. Try the more aggressive curve, if it runs like shit or kicks back on startup drop it back one. No need for a dyno.
MARV
Ultima motors use the same ignition. In their manual online they have the best description on setting it up.
Your build sounds like mine and 28 degrees BTDC is the sweet spot
stlmikie
I wish I had more money.
Hey Mike! It's Mike! I have an 03 Mastiff. I think I rode with you last summer with Ryan S. if you need a hand let me know and I'll rally the troops we'll head out.
And by the way. Mikes 107 is putting down 125 HP!
Preston
I just installed a ultima ignition in my 107. It is a Dyna system with a Ultima package. Even has Dyna part numbers. Came as a kit with coil and plug wires. Was cheaper than the Dyna kit. Any how install is easy and static timing was near dead on.
