DSSC GASKET
Justintime
I just received a primary gasket kit from Baker. My outer primary cover and the inspection plate have the o-ring seal but in the kit they include the o-rings and a "paper" gasket for both. Which one should I use? I test fitted the paper gasket and there will be a visible gap between the inner and outer primary, with the o-ring they are tight together. Is one better than the other?
V
05 had the o-ring. My 08 has the paper/fiber gasket. But this was only for the inspection cover. The main primary case gasket I bought about 30 days ago was o-ring.
Nukeranger
Nukeranger
Gasket number for a 2008 is 3027G-DSSC ($2.50) and the Chrome Inspection Cover is 3027-DSSC ($82.50). Call Amy at Strokers to order it from Baker. She'l have the gaskets unless she sells out.
