I think they are 1 1/8" wide, if you have a 1/4" space there's sumth'n wrong, has the belt been rubbing on the tire? Also you should check your wheel alignment.Hello, Does anyone know the exact width of the drive belt on a 2006 K-9 Big Dog? My belt has a quarter inch space on the rear sprocket! Thank you, Mike Toz!
I'd stick with the 1" belt. The 1 1/8" will rub the outside edge of the pulley and squeal.Thanks Cdogg, Belt does not hit tire my belt is 1 inch wide. Where can I purchase proper sized belt?
Yup, your only talking .125 . That aint enough to be concerned about. The squeal however WILL give you cause for concern. Listen to Bill and be happy riding. LolI'd stick with the 1" belt. The 1 1/8" will rub the outside edge of the pulley and squeal.
