be about a month since I fixed my clutch... I had some odd sounds pop up.. first it sounded like the front cylinder had a miss or piston slap or something I looked and looked to figure out what it was.. well today I realized my front spark plug was loose! hope that fixes it! also... I have been hearing a sound from the left side that sounds like something is loose! I keep changing my mind on where its coming form ( but its not the tank lol) so as I was coasting downhill threw the park yesterday with the clutch in... as I hit every bump I heard a sound that sounded like the primary chain hitting the case.. hmmm... so I checked it out today.. it was a little loose but not what I would consider to bad.. maybe an inch.. I readjusted that.. and then realized my primary fluid is extremely low..
so not to ramble on.. but ... where in the F@#! did it go!?!? I have been watching and there are no leaks.. even looking under the bike.. you can rub a white glove across the under side of that bike.. no drips in the driveway or anything...
can primary fluid get hot and evaporate? lmao
