Off the wall guess. Is your headlight lighting up? When both filaments are burnt out it will switch back and forth between High and Low beam. Maybe somehow your getting the effect of that.Yes it still flashes I’m from Louisiana too
No it’s the Speedo it’s too bright and over powers headlightOff the wall guess. Is your headlight lighting up? When both filaments are burnt out it will switch back and forth between High and Low beam. Maybe somehow your getting the effect of that.
if I go with a DakotaThink I need the original mounting bracket too
I tried calling JP they knew nothing and couldn’t get any furtherMaybe call ur speedo company and ask them is there a setting that u like
