cranks good, won't turn over!
my 2008 pitbull is cranking nicely but it will not turn over! I forgot and left the fuel on all winter and it seems at some point the 7.5A fuse blew while the tender was doing its thing so after replacing that, charging the battery and giving the key a turn it cranked....but no vroom! I'm gonna remove the plugs, check them (new) and hope I did not flood the damn thing. any suggestions?
thanks!
R
heybaylor
while you have the plugs out , ground them on the motor and check for spark.
only need three things to run , compression, fuel ,and spark.
one of them aint there
MossBerg590
Sounds like the carb is plugged and not getting any fuel. Take off intake and twist throttle and see if you see any gas spray in.
BadDawg Bill
"2008 pitbull is cranking nicely but it will not turn over! "
It can't crank AND not turn over....
It cranks and turns over but it doesn't start.
1- No spark
2- No air
3- No fuel
Pick one.... and go for it... Gezz newbies....
francoblay1
The Spaniard
As said above, plus give that Carb a thorough clean.... special attention to the jets.
PM me your email if you need Manuals :up:
