Cracked exhaust
IMG_9751.jpegHello gang. I recently removed the heat shields on my ‘07 Mastiff. Not sure if you would call it the top exhaust or the rear exhaust. I removed it because it had exhaust wrap under the heat shield (that I assume was to keep the heat down to not melt the battery cover plastics) that had broke loose causing higher heat making the plastics melt a little. So I was going to replace the wrap and found that the pipe had a major crack in it. So I’m not sure if it was wrapped to hide the crack when I bought the bike or what. But my question is, can this be fixed or am I going to have to buy a new exhaust? I’ll add a pic so y’all can see it. Thanks for any help/advice.
