Cone air cleaner???
Wanting to buy a cone style cleaner and mount it horizontally. But reading posts of people having jet problems so is it a good idea and if so any suggestions where to buy one and jets if need to rejet? Its on a 08 k9.
aspen874
some people have had problems that re-jetting doesn't fix, others have not, I couldn't get mine to work even after having it on the dyno at Gateway BigDog. I went with the dual runner and zero problems. They do look great, hope you are one of those who don't have any issues
1BADK9
Limited Edition Member
Here ya go chummy dog, you can buy everything your heart desires in bad ass air filters here. I run a D&M spike and have never had any problems horizontal or vertical. They sell all sorts of filters here.
D&M Custom Cycle - Air Cleaners
ringo
if your carb is on the lean side you can have issue's. Go with Brooks suggestion with D&M. A little pricey but good stuff.
I have the D&M spike and had problems with it horizonal. But only in cool to cold weather. Always at 65 to 70 mph. It would stumble sometimes. Tried changing the jets and it would be ok until the weather changed again. Turned it vertical and no more problems.
No one has mentioned the air bleed.
The spike air cleaners almost always need an adjustment to the air bleed on carbureted bikes.
1BADK9
Go powerflow and you wont have the problem you get with the spears.
I've run my D&M spear horizontal and vertical in all weather conditions and at different altitudes and NEVER had any problems......what you talking about......problems?????
Brew
5 years and still going with no issues (except a cracked frame :-( )... Aux bowl vent screw removed and running 31 int / 78 main for jets... :D :2thumbs:
