Compression release relay
Chrisnjax
I have an 05 Pittbull that has undergone alot of battery box wiring mod , with a Thunderheart Ign and a Bad lands lighting controller .. in the process of cleaning up the wiring I may have screwed up the connection locations on the compression release relay .. can anyone snap a clear pic of theres or let me know which go where ?? chris.krash@comcast.net 904.444.1437 thanx !
Moespeeds
There is no compression release relay unless someone added one. It takes a direct 12V, so just hook them up to the big lug on the starter that goes HOT when you hit start. This way every time the starter is turning, the compression releases will be open. No need to fuse it.
