Nomad2day
Longhair Redneck Geek
I have a 2007 Bulldog that I just put back together after the winter. In 3rd gear the primary chain clunks like it is locking up or perhaps the clutch is slipping and I hear the primary chain popping when it grabs. It will jump a time or two and then pull normal and then jump again. It does not keep just clunking all the time is what I am saying but will do it even if you are jusr riding steady. It does not do this in any other gear. I went to pass a car on a back road and blam or clunk, clunk in third. It will do it at low rpms or if you twist the throttle in third again all off sudden.
The clutch is a new stock clutch hub basket and clutch pack from BDM which they sent back with my transmission when they were looking at the tranny for this very issue this past winter. They never did tell me if they found anything and the dealer said the tag just said rebuilt transmission. Everything held good for about a week and they it started clunking after a 60 mile ride to Nashville on the way back.
The bike makes over 140 tq. at last check but I will not know for sure until I correct this and dyno it again.
Is 3rd gear and high torque a indicator of the stock clutch not up to the job causing this issue or do I need to look elsewhere.
How do I tell what spring rating is on the clutch diaphragm and where can I get the highest rated spring to help find my root cause here before I purchase a Bandit clutch not knowing for sure if this is my issue.
Backflash here of the last few weeks........
A couple of weeks ago I get the transmission in from BDM, powder coated wheels, new final drive belt and everything back together. Drive it to work a few times a week about 10 miles each way half interstate and half back roads and around town in the afternoons.. Thursday evening coming home I stop to get gas and the starter takes a shit and shears the jack shaft in half. Order one off of ebay. Put it in Thursday night and notice the final drive belt has loosened up a fair amount so I adjust the rear wheel to tighten the belt after installing the starter. Drive to work Friday and then to Nashville Saturday morning 60 miles all interstate. Going home the back roads I pass a car in third and the bike lunges and couple of times like it has slipped or as explained above. Bike has 300 miles are so on it from putting it on the road.
Thanks for any info,
Neil
Neil
