Clutch pivot plate??
Woody1127
I took apart my clutch assembly to check my clutch hub nut. Replaced it with the new hardened one. Upon reassembly I didn't get the 4 tabs on the clutch pivot plate to go inside the notches on the clutch diaphragm spring. Is this correct? I can't remember how it was when I disassembled it. :bang: Should the tabs just stratel the top of the notched out section of the diagram spring?? Thanks for the help!!
Woody1127
I took it back apart. I thought the 4 tabs on the pivot plate where bridging across the slots on the clutch diaphragm, but they are not.
