texvet16 Active Member May 31, 2012 #1 I have an 07 K9. I am in the process of changing my clutch. How much movement should the bearing carrier have in it? if any:loony:
Bobby Schulz Active Member Jun 5, 2012 #2 If you are talking about the carrier bearing that is part of the clutch assy not much. I would say if you can feel the slop in it you have too much.
texvet16 Active Member Jun 5, 2012 #3 I found out why i had movement in my carrier bearing. I had already taken the nut off the shaft.
