Splitlog
Ok, clutch slipping in 4th and higher gear..
pulled primary and sure enough the main rod was
loose..tightened and locktite to 100 lbs. per bulletin from 80 lbs.
put all back together drove it and perfect no slipping at all
for about 35 miles...now 4th is slipping again..
I adjusted clutch rod. backed it off a little but have not had a
chance to ride it..
Any Ideas? if the clutch was worn I would think it would
have slipped the first 35 miles after going back together..
I have 8500 miles on the bike...:bang:
chance to ride it..
