Clutch Cable
T.Byrd
While riding today when I pulled the clutch in it stayed about half way in and the clutch did not work. I took the cover of where you ajust the clutch and when you pull the clutch in it turns a little. I don't think the cable is broke but I don't know.Any advise. Thanks:
T.Byrd
Went back out and was messing with it and the cable broke the rest of the way. I didn't know it was the cable because I drove it about 50 miles home today with out touching the clutch cable.Thanks Eric .
BBChopper
Supports 2 Disabled Vets
I call that lucky T!!! Mine broke clean!:cheers::2thumbs:
T.Byrd
BB I still had to ride 50 miles with no clutch. Its fun in town through the stop lights and all.
Did the same for 45 miles with my wife on the back about 2 months ago. Mine was the clutch nut. Cleaned the nut and tightened to 150#, took it off and loctited it and torqued it back to 150. If it comes loose again I will tack weld it on the shaft.
