(1) Whenever a current of electricity flows through a conductor, it produces a magnetic field around the conductor... [insert battery posts].
(2) Whenever a current of electricity flows thru a conductor, the wire becomes heated.
(3) Sometimes, an electric current may produce a chemical effect...
...Fundamentals of Electricity by Theodore Benjamin
Ahhhh... said the blind man feeling the white/green crap on the battery terminals, wipes it on his pants and now holes galore in his Levis. So he found a straight edge razor, scraped the top of lead post clean and at the bottom side or the touch side of the cable end to the battery post, vaseline is used there and also to coat all the nuts, bolts, touch pads [that were scrapped off] so raw metal to metal is now the fresh contact... I need to remember, 'magnetic field-heats-my chemical reaction' and will happen to my battery posts I do not grease with vaz so lean am I pushing my bike home and that exercise is choose your poison.
Very typical... so typical I did not vaz my batt cables and lead posts/screws/nuts... "Hello, pick me up." ... gets home to pull the batt and oh look, Moe! Clean my posts is yes, the battery was being fed current back in, but the load stops at the posts---> No crank... First check is to look at the batt posts for corrosion.
Signed,
NOLTT heading for the med cabinet.
P.S.
Dip the corroded battery cable end into a cup of vinegar and when the bubbles stop... Mr. Clean-- Mr. Clean! Dip in fresh water to neutralize--scrape for a fresh raw surface--coat with vaseline, etc.
