Chatter when accelerating...
Bmarchant
Hi Guys,
I thought I'd post this, in case it happens to someone else, there will be a post of it. The last few weeks, I've noticed a chatter that was getting worse, as I accelerated. Took it to my brother in laws shop last night and he looked at the clutch and adjusted it, which ended up being fine...... Though now it goes into neutral a lot easier after he adjusted it. Turns out the drive belt had too much play in it, causing the chatter that I was feeling. Didn't realize belts need to be tighter then chains.
Thought I'd post the issue and fix since it was driving me crazy all week, and I ended up checking everything from frame recall, to wheels not balanced to the top motor mounts. The research was a great learning experiance though, so I can't complain.
Bmarchant
