carb question
waternazzi
Hey Guys,got a question for ya.. today i figured i get the pibull out and fire it up for a bit to get the fluids circulating so when i went to pull the lever for the choke it wouldnt open,pull up etc.finally i really had to put some effort to lift the lever.wow any ideas what could be wrong?
Brew
Just give it a couple cranks on the throttle, start it up and let the engine heat thaw it out.
RADAMS445
RADICAL
Couple drops of PB-Blaster,Freeall,WD-40,3in1oil,marvels mystery oil,Wesson cooking oil...Whatever works.:roll::roll::roll::loony:
try some carb cleaner, it should evaporate quickly but you should also be able to break the "enrichener" loose before it is gone.
thepearle
I USE 4 OZ'S OF MARVELS MYSTERY OIL TO 10 GALLONS OF GASOLINE IN EVERYTHING THAT I OWN. LATELY IN MY BIG DOG & JOHN DEERE TRACTOR I'VE BEEN PUTTING IT IN THE OIL ALSO ! RUNS SMOOTH AS SILK !
