Can’t change the gear when bike is cold
Martin_es1988
Hello guys, i ve got a problem with clutch or gearbox. Actually I dont know. When I am taking Biggie out of the garage I put 1 gear and ride out and than when I want to put neutral I can’t move it so I have to switch off the engine . But after that When Biggie is warmed I can change the gears and neutral without problems. Do you know what it can be pls?
Jersey Big Mike
100K mile club
Check the easy stuff first.
Check the fluids in primary and transmission
Check clutch adjustment
Has anything been done to the bike before this started?
Sounds like a warped clutch plate bent then straightens out when warm. Pull steels, palm them all in one hand and spin the stack while looking for a gap between plates. Replace the bent one.
Martin_es1988
Hi, all the fluids were changed with front break pads and carburetor. Clutch adjustment already checked. Nothing helps.
Martin_es1988
Hi Sven, thanks for the tip. That sounds like it could happened, but I have no idea what half of the words means and google talks shit do you have any photo of it. What to replace etc. I am really not technical guy, but I want to be one day ☝
Martin_es1988
Hello Frank, well I bought 2004 Mastiff 1917ccm in february and I ride just around the house and problem with the clutch came before the fluid change. It was lil bit better when I did few spins on clutch hose, but still when its cold I cannot change the gear.
heybaylor
what weight oil is in the primary ? could be too thick and when cold drags on the clutch plates?
You did say when it warmed up it works fine .
Also too heavy of a oil in transmission can cause that.
After I replaced my synthetic oil with belray in my tranny , my Fatboy acted like that ( worse in colder weather )
Hope this helps
At the 2 minute mark, the tech places the steels all together on the bike rack. You're looking to see how flat those steels are when they lay on each other. This is how you can see one plate rises off the other. When you pull the lever, all the plates are flat so they move away and no drag. But let one warped clutch steel have a wave, it touches the friction and there is your problem finding N.
chubs
How much oil is in the primary ? over filling can cause some problems also,
according to the manual.
FrankBDPS
That's exactly the point I was hoping to make about the primary oil. My 2000 year bike has a Primo Revera clutch in it. They actually recommend automatic transmission fluid for their clutches. I have never had any issues with the clutch not disengaging when cold or slipping under a hard acceleration load.
Of course I put a Kenda tire on it and there is no way in hell that fucking thing will ever hold the power from the 107.
