pulls hard enough now with the 640 and the high compression.Thought you were dropping in the W9F ? Gonna stay with the 640 ? I would have thought the lower duration of the woods cam would have sucked you in.
Did you sell the BMF?will use the cash from this to put towards the LSR. :up:
no.Did you sell the BMF?
The 08 models have the single wound behive spring thats rated at .585 and standard rockers (not roller tip). Depending on your motor in the 07 you may have the same.Hey Marv does that 640 work ok with the stock compression, or does it need to be bumped? Also do you know if the 640 is ok with the stock springs in an 07?
A nearby shop thought the 640 would be a good choice.
sold!Marv i want the .640 cam,gears,and the springs p.m. me !!!!
