sigma01 - I have an 03 Pitbull & had to replace mine too.
FYI- The original manufacturer, THUNDERHEART, calls them "trigger plates".
I sent mine to Brooke @ Thunderheart and had them test mine.
Because I sent it directly to them for testing, they gave me a new one at "cost".
I think it was around $36.
Also, I would send your Ignition Module to them as well, since its a Thunderheart too.
They didn't charge anything to test them. There tech, Larry, contacted me within 2 days with the results.
Just curious, what symptoms are you having that make you feel your's is faulty?
Try this for me:
1) Take off the seat and make sure the connections are good from your Ignition Module (The metal box mounted to the rear fender about the size of a credit card).
2) Turn the key to "ON".
3) While keeping an eye on your ignition module, press the "RUN" button.
a red LED light should light up for a few seconds on your Ignition Module, then go off.
4) Now press "START" while still watching your Ignition Module. The red LED light should 'flash/pulsate' as you are pressing the START button. The flashing LED confirms that your trigger plate (cam sensor) is most likely not the problem & is in good working condition.
Also, I would do a search on here for how to test your Ignition Module, Trigger Plate / Cam Sensor, Ignition Switch, & Coils with a multi-meter.
I just got done chasing what I thought was the same issue.
Hopefully I can save you some time &/or lead you in the right direction.
Feel free to PM me.
Here is Brooke's contact info from Thunderheart:
Brooke Padgett
Customer Service
Thunder Heart Performance
120 Industrial Drive
White House, TN 37188
615-616-1127
615-672-1353- fax
brookem@thunder-heart.com
