blackdogg6164
what type of cable lube is recommended? I know WD 40 is out of the question.
I think it's good practice to take it apart and run the lube through to grease up the wheels so to speak. I never lubed my Teflon one and it broke with about 9k miles while I was 250+ miles from home. Won't make that mistake again and actually the 05+ Baker Trans is an easy disassembly no need to drain any fluids. Where as my Jim's unit on the 04 Id have to drain the fluid.Are y'all lubing the cables with the Teflon lining ? I only lube them at the lever
Damn I've never been able to get much lube in that way.I lean the bike as much as I can and squirt a good dose from the top (at the lever) so it goes down all the way... first time I put too much and it was coming out by the bottom end. No problem, just had to clean the frame. LOL
