EZ Dog
I just replaced my started with my backup starter I has the Kaptain rebuild and add a slam button. I doubt the starter has any influence on my problem but the saving grace to it is the slam button.
When I turn on the ignition switch I instantly blow the 5 amp fuse controlling the starter/ headlight circuit.
Previous to this I could turn on the ignition switch without blowing the fuse but as soon as I would hit the starter button I would blow the fuse.
Prevoius to that I went to start the bike and I had nothing when I hat the start button. I then found I had a blown fuse. Replaced it and it immediatel6 started but the next time I went to start it I had a blown fuse.
I have removed the handbags control switch and have disconnected the wires to the switch except the permanently soldered off/run power connection. Aft the disconnection of the starter switch andq the lead wire going to the starter that I think actuated the solenoid switch I turned on the ignition and the fuse blows.
I can turn on the ignition switch, hit the run button, push the slam button and the bike starts easily with a blown fuse in place.
It must be my ignition switch or PDM not blowing the starter circuit and effecting the starter switch controls.
I'm not electronically skilled, I'm just a wrench.....
